Forums >> Community >> Newbies >> How do I ad a material to an imported family ?
Wed, Dec 25, 2013 at 6:50:32 AM | How do I ad a material to an imported family ?
hyronimus
I'm having a problem aplying materials to imported famelies. For example in the image below. The materials and finishes property is gone. I think I need to make the model solid but don't know how. Can anyone help me ?
Kind regards,
Thu, Dec 26, 2013 at 7:34:49 AM | How do I ad a material to an imported family ?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
This is just an imported .dwg file, you can't add a material to it in Revit as it is just lines
Thu, Dec 26, 2013 at 10:06:17 PM | How do I ad a material to an imported family ?
CDWdavid
5 Stars: 5 Votes
You may try the method in following thread.
That works for both AutoCAD and SketchUp imported 3D figures. You need to apply proper layers to it in the original program.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=29146
If the figure does not need to be shown in a very detailed way. You might get an acceptable result.
Hope that can help.
Edited on: Thu, Dec 26, 2013 at 10:13:52 PM
Massing - Applying Materials to Imported Geometry from Rhino-HELP!
Sat, Dec 10, 2011 at 6:30:09 AM
material tagging a family
Mon, Apr 15, 2013 at 4:12:46 AM
How do you add an imported material to Revit's material library ?
Mon, Aug 16, 2010 at 8:06:17 AM
Adding a material to a mass imported from Rhino
Fri, Oct 22, 2010 at 2:27:31 PM
Material on imported families
Tue, Dec 1, 2009 at 5:43:14 AM
Page generation time: 2.2880
