Forums >> Revit Systems >> Technical Support >> Pre-insolated duct family
Tue, Dec 24, 2013 at 1:08:01 PM | Pre-insolated duct family
Revitee
i am going to start a new progect in revit mep . in this progect i have to
create some ductworking which are pre-insolated (PID) but there is no familly in revit mep
for these kind of ducts there are just sheet metal ducts  .is there any place to download them
if not whats the best solution ?
thank you very much for your help
Fri, Dec 27, 2013 at 2:46:09 PM | Pre-insolated duct family
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What is the difference in the pre-insulated and just the sheet metal that you need?  Are you going to schedule anything about the ductwork other than the size?
After a little searching I found this site  http://www.kingspanair.com.au/News/2013/Kingspan-Releases-BIM-Models-for-Pre-Insulated-Ducting.aspx
I did not try the families but it may be what you are looking for.
Edited on: Fri, Dec 27, 2013 at 2:48:46 PM
Capping a Duct
Tue, Jan 21, 2014 at 9:46:17 AM
Duct accessories family do not break into
Tue, Nov 5, 2019 at 8:55:37 AM
Duct Fitting Issue
Tue, Apr 1, 2014 at 1:16:35 PM
Help with a duct family -trying to prevent resizing by dragging or limiting drag
Fri, Dec 10, 2010 at 10:23:31 AM
Family Editor - Duct Connector
Mon, Jun 16, 2014 at 1:52:01 PM
Page generation time: 1.8024
