25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> attaching edges
Hi, I am using Revit 2014
I am modeling something organic using the conceptual mass . I made two masses and i need to connect them together . the attached picture is showing an example of what i need , I cant send my real model because its confidential.
So my question is how can i connect or attach the two edges ??
* I know in this case (the one in the sent picture) i can delete on of the planes and extrude the edge itself ,BUT in my case i have two complicated models that i need to connect together.
Thank you ,
Why is it 2 different masses? Just create it as 1
they are 2 complicated masses i cant create them as one from the start
and i already spent alot of effort doing them
You can't join them if they are two different masses like you are trying to do.
Edited on: Tue, Dec 24, 2013 at 8:17:56 AM
Create just a portion of the other mass in each model so that the face in that model will be correct. Then you don't need to join.
Column Automatically Attaching to Ftg |
Thu, Sep 2, 2010 at 10:40:33 AM
shading with edges problem |
Wed, Nov 17, 2010 at 6:49:49 AM
creating a chamfer on edges of an extrusion |
Tue, Apr 21, 2009 at 5:47:05 PM
edges color and linetype |
Thu, Apr 21, 2005 at 10:07:34 AM
sketchup imports dont show edges withing planar facees |
Tue, Mar 6, 2018 at 5:59:52 PM
