Forums >> Revit Building >> Technical Support >> Controlling visibility of nested families in familes with multiple types
Mon, Dec 23, 2013 at 12:45:58 AM | Controlling visibility of nested families in familes with multiple types
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Hi All,
I am creating a door family in Revit 2013. It has four different door width sizes with all parametrics created within the main family.
I have created a number of additional families made from 2D linework which show disabled access setbacks from the door. Each of these are nested in the main family on top of one another.
I want to be able to do the following:
1. Select a door width and for them to be unable to change the door width.
2. With a door width selected, I want them to be able to turn on and off the nested family that applies to that width. All other nested families for all the other door widths need to be greyed out ( or turned off).
Thanks all for the help and merry xmas.
beau
Fri, Dec 27, 2013 at 2:55:48 PM | Controlling visibility of nested families in familes with multiple types
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
1. I don't understand this. You want to select a door width and then not be able to change the width??
2. Can you attach your family for us to take a look at?  It sounds like it would be easier to just make the door parametric and change it to whatever size you need than have to worry about only having 4 sizes
Mon, Jan 6, 2014 at 2:08:48 AM | Controlling visibility of nested families in familes with multiple types
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Hey Teafoe, thanks for replying.
Family attached as it stands.
Answers to your queries:
1. 4 fixed door widths, 850/900/950 & 1000
2. Attached
Mon, Jan 6, 2014 at 10:37:45 PM | Controlling visibility of nested families in familes with multiple types
gprakash
Hi Beau,
I did not open your attachment but from your initial post, I understand that you are looking to make types for each individual door. I think, you can try visibility parameter (Yes/No) for turning off all other doors in the type parameter for one particular type.
I am not sure if you are looking for something else.
Cheers.
How to create an <invisible> dashed line?
Wed, Jan 8, 2014 at 7:57:41 AM
Controlling Visiblilty Of Multiple Families
Sun, Nov 4, 2012 at 10:16:48 AM
controlling/setting Visibility Graphics for multiple Views
Mon, Oct 4, 2010 at 2:22:12 PM
Multiple Tags on 1 family in one view
Thu, Jun 23, 2011 at 2:42:42 PM
Replacing Multiple families in a Project.
Mon, Oct 15, 2018 at 10:34:29 AM
Page generation time: 3.3234
