14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> how can I prevent revit from snaping to the pattern ??
Hi , I am using Revit 2014.
When you have a floor and you assign material that has a pattern (Tiling grid for example) to that floor . revit start snaping to the pattern, and its the last thing that you usually want to snap to . So, is there anyway to stop the snap to the pattern lines ?
Regards,
Use your tab to snap to what you want.
Unfortunately this is not a suitable solution in many instances. I have mosaic tiles in a pool and it is nearly impossible to tab through all the lines.
Isnt there a way to turn off fill/hatch snapping?
So hide or turn off the hatch.
Is it possible to prevent people accidently put object in certain workset? |
Tue, Dec 7, 2010 at 4:07:05 PM
Floor pattern not showing up when the pattern is model pattern |
Fri, Nov 3, 2023 at 9:11:59 PM
how to download pattern in revit? 2009, 2008 etc... |
Thu, Aug 13, 2009 at 7:01:11 AM
create a custom fill pattern [ 1 2 ] |
Mon, Jun 28, 2021 at 2:32:51 PM
29
Help with a duct family -trying to prevent resizing by dragging or limiting drag |
Fri, Dec 10, 2010 at 10:23:31 AM
