Forums >> Revit Building >> Technical Support >> Room Number on Ceiling Plans
Fri, Dec 20, 2013 at 10:20:34 AM | Room Number on Ceiling Plans
clopez
How do I get the room numbers to show up on the ceilin plans?
Fri, Dec 20, 2013 at 10:25:33 AM | Room Number on Ceiling Plans
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
tag the rooms in the reflected ceiling plan
Fri, Dec 20, 2013 at 11:05:30 AM | Room Number on Ceiling Plans
Make sure you turn on rooms in VG.
You can widow your floor plan, filter that for room tags, copy those to clipboard and paste same place in your ceiling plan.
Fri, Dec 20, 2013 at 11:26:55 AM | Room Number on Ceiling Plans
clopez
Thanks
Mon, May 5, 2014 at 7:53:49 AM | Room Number on Ceiling Plans
joeinck
I am having this issue...rooms is turned on in VG for my ceiling plan.
Am I understanding correctly that you can not simply have room numbers appear in a ceiling plan?
I don't want to copy and paste stuff, that is just a mistake waiting to cost me money...is this really the only solution?
thanks for you help, the conversations and downloads on this forum are quite helpful
j
Mon, May 5, 2014 at 8:02:03 AM | Room Number on Ceiling Plans
The copy/paste is the simple way but if you don't know how to use your filter (funnel), then you are looking for trouble on more than just this.
Just tag your rooms!  Room tags and rooms must be on.
Room Tags on Ceiling Plans
Fri, Mar 4, 2005 at 9:36:28 AM
Visibility Parameter in Room Tag
Fri, Jun 4, 2010 at 6:01:09 PM
Bookend Room Schedule with Room Number
Mon, Apr 18, 2016 at 10:54:09 AM
Room Tags on Reflected Ceiling Plan. Why so difficult!
Wed, Apr 4, 2007 at 4:21:33 PM
HELP! - creating tags
Fri, Apr 22, 2005 at 1:58:25 PM
Page generation time: 3.7737
