Forums >> Revit Building >> Technical Support >> Aluminum Framed Galls Door insert in Curtain Wall
Thu, Dec 19, 2013 at 12:51:10 PM | Aluminum Framed Galls Door insert in Curtain Wall
MongooseST1
MongooseST1 Avatar
I have downloaded a couple of aluminum frame doors from this site to insert into a curtain wall. I used the load family command to bring them in and I can see them in my Project Browser but when I try to drag and drop nothing happens.
Moreover I have used the DOOR command to insert the newly uploaded door family but it is NOT in the Properties box where all the doors can be selected for the project.
I have also tried to upload the REVIT generic galls curtain wall door that comes with REVIT bu the same holds true. In prieor verisions I never has this problem I am using REVIT 2014
Thu, Dec 19, 2013 at 1:08:09 PM | Aluminum Framed Galls Door insert in Curtain Wall
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can't just drag and drop a curtain wall door into a project, it has to be PART of the curtain wall so click on a curtain wall panel and change the type from glass to door in the type selector pulldown
curtain wall door
Tue, Jan 31, 2006 at 1:36:58 AM
Curtain wall door frame
Mon, Mar 2, 2015 at 11:37:33 AM
Aluminum panel wall
Tue, Jul 6, 2010 at 10:02:21 AM
Curtain Walls + Door Legends
Thu, Dec 7, 2006 at 1:30:39 PM
Curtain Wall Panel to Curtain Wall Door
Page generation time: 6.6377
