Forums >> Revit Building >> Technical Support >> Section callout missing
Mon, Dec 16, 2013 at 1:04:28 PM | Section callout missing
MongooseST1
MongooseST1 Avatar
I have a section view indicated as Section 3 in the SECTIONS area in the project browser. However I cannot find the callout in plane so I can change the callout's placemnet. I already have details referenced to Section 3 so I do not want to delete to start over. Where is it on the plans? I cannot find it or is there something I am missing here. I have rioght clciked on the actual Section 3 to see refering views but there aren't any
Thanks in Advance
Mon, Dec 16, 2013 at 1:30:22 PM | Section callout missing
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Can you see other sections on your plan?  Is it off in Visability Graphics?  When you click on the section in your project browser is it set to show at scale set to something to big or small?
Mon, Dec 16, 2013 at 3:53:05 PM | Section callout missing
MongooseST1
MongooseST1 Avatar
Can you see other sections on your plan?  NO I CAN'T. IT IS SET LIKE ALL THE OTHER SECTIONS I HAVE AT 1/4"=1'-0" Is it off in Visability Graphics?  NO, EVERYTHIG IS TURNED ON.....When you click on the section in your project browser is it set to show at scale set to something to big or small? 1/4"=1'-0"
Mon, Dec 16, 2013 at 3:59:24 PM | Section callout missing
Do this.  Create a new floor plan from the view / plan / floor plan (uncheck the do not duplicate box)
Do the sections show now?  If not, then look at the view properties.  If you are on 2013 or 2014, you may have a view template applied that has sections turned off.
Mon, Dec 16, 2013 at 4:00:09 PM | Section callout missing
MongooseST1
MongooseST1 Avatar
Found IT!...The HIDE AT SCALES COARSER THAN....WAS SET AT 3/4"=1'-0" RATHER THAN AT SOMETHIGN LIKE 1/4 OR 1/8........IT THEN APPEARED IN THE FLOOR PLAN WHEN IT WAS SET AT 1/8".................
Section callout missing yet Section still Exists
Mon, Feb 20, 2012 at 3:34:46 PM
Building section callout visibility in intersecting views
Mon, Jun 16, 2008 at 12:40:58 PM
Callout or not callout
Tue, Sep 23, 2014 at 9:55:26 AM
Detail Callout Bubbles and Dependent Views
Thu, Aug 12, 2010 at 6:51:10 AM
DETAILS IN SECTION CALLOUT
Mon, Apr 21, 2008 at 12:45:37 PM
Page generation time: 0.5028
