Forums >> Revit Building >> Technical Support >> Wall Finishes
Sun, Dec 15, 2013 at 10:46:51 PM | Wall Finishes
CDWdavid
5 Stars: 5 Votes
What is the best way to model this in Revit 2013?
2x6 stud wall with 1/2" plywd sheathing to the underside of sloped roof sheathing at 10'-6"; exterior finish: 7/8" stucco up to 9'-0" high flat soffit w/ 2x4 joist; interior finish: 1/2" cement board with ceramic tile up to 8'-0" gypbd ceiling w/ 2x4 joist.
This should be a very common simple structure. However, I could never find a simple way to do it.
My wish is that the Revit can allow me to create a basic wall with all finishes as above, create the sloped roof, create soffit and ceiling; then pull down the stucco to the soffit, cement borad and tile to the ceiling and able to join all finishes cleanly.
Hoping someone can help me on this. Thanks in advance.
Edited on: Sun, Dec 15, 2013 at 10:53:27 PM
Mon, Dec 16, 2013 at 7:40:53 AM | Wall Finishes
I think you need to show us a section.  You do understand how to unlock wall layers?  if not, then read this topic:
"Modify Tool for Compound Walls"
Wed, Dec 18, 2013 at 11:00:25 PM | Wall Finishes
CDWdavid
5 Stars: 5 Votes
Hi WWHub,
Please see attached drawing. I know how to unlock wall layer, but when the wall attached to the roof, that function no longer works.
Here was my question:
Edited on: Wed, Dec 18, 2013 at 11:03:35 PM
Thu, Dec 19, 2013 at 7:40:50 AM | Wall Finishes
If  must model this, (Edit cut profile works in section/detail views otherwise) I often split those walls horizontally at the top of the interior change.  Then I change the upper portion to a wall type without an interior finish.
BTW - Pay attention to layer controls for joining.    This topic in yourr HELP:
Applying a Function to a Layer of a Compound Structure
Thu, Dec 19, 2013 at 2:29:13 PM | Wall Finishes
CDWdavid
5 Stars: 5 Votes
Thanks! That helps!
Fri, Dec 20, 2013 at 2:18:02 PM | Wall Finishes
jtebok
You can make walls that have a different make up after a certain hieght.
When you are in the wall type box swtich the preview to section, then you can basically pick a hieght on the section and change the wall types on either side of the line to something different... I do that a lot with ex. walls that have different veneers, seperated by a precast band or something. That way it is one wall; instead of cutting a wall and having two walls one on top of the other.
Fri, Dec 20, 2013 at 2:26:15 PM | Wall Finishes
CDWdavid
5 Stars: 5 Votes
Hi Jtebok,
Thanks, I'll give a try.
Merry Christmas and Happy Newyear!
Internal Wall Finishes
Tue, Mar 25, 2014 at 4:18:18 PM
Creating a wall finishes schedule, and coding wall finishes on elevations
Fri, Jun 1, 2012 at 4:06:32 PM
wall finishes by room
Tue, Apr 19, 2005 at 11:40:25 AM
Wall finishes and grade
Tue, Aug 31, 2010 at 12:33:10 AM
Multiple Wall Finishes.
Thu, Dec 12, 2013 at 11:02:29 AM
Page generation time: 1.3794
