Forums >> Community >> The Studio >> rendering floor plans
Sun, Feb 19, 2006 at 9:44:02 PM | rendering floor plans
dj05
I wanted to render a floor plan with meterials..... I have used a camers to creat a view, but I wanted to keep the walls flat.... any Ideas??
Sun, Feb 19, 2006 at 11:42:29 PM | RE: rendering floor plans
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
what do you mean flat? Do you mean flat shaded, as in a single colour... If so, best to do a few different exports of the same view (rendered and shaded) and blend them in photoshop. If you don't want to see your walls vanishing, orientate a 3D isometric view to top and render it that way. HTH. Post edited on 2006-02-19 23:43:58
Sun, Feb 19, 2006 at 11:56:14 PM | RE: rendering floor plans
dj05
thanks for you help....Isometric top view is what i wanted Is there any way to edit the cut plane to show the doors and windows.... also can you add text or would that have to be done in photoshop thanks
Mon, Feb 20, 2006 at 4:44:32 PM | RE: rendering floor plans
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use the view -->Orient-->Other Then pick your floor plan you want. The scope box and view of the 3D will automatically be adjusted to match your floor plan. You can add text on the sheet. Dimensions can be added directly to the 3d View. HTH
Mon, Feb 20, 2006 at 5:31:56 PM | RE: rendering floor plans
dj05
I have add a level which would cut the through the plan, but when you change the orient to the new level the 3d image doesn't change....... It will not cut the wall Am I doing this right???
Mon, Feb 20, 2006 at 5:33:14 PM | RE: rendering floor plans
dj05
I have add a level which would cut the through the plan, but when you change the orient to the new level the 3d image doesn't change....... It will not cut the wall it still remains to view the top of the walls Am I doing this right???
Enlarge Floor Plans
Thu, Feb 12, 2009 at 4:12:21 PM
12
Best Software to Create Presentation Floor Plans
Fri, Apr 30, 2010 at 12:56:47 AM
Using Area Plans as Main Floor and Unit Layout plans
Mon, Mar 29, 2021 at 1:59:33 PM
MAP TEXTURE IMAGES TO ELEVATIONS AND FLOOR PLANS
Mon, Mar 5, 2007 at 2:39:54 PM
Second Floor Floorplan Gone
Wed, Sep 4, 2013 at 8:08:55 AM
Page generation time: 1.1203
