Forums >> Revit Structure >> Technical Support >> Stair not joining first floor slab properly
Sat, Dec 14, 2013 at 3:13:55 AM | Stair not joining first floor slab properly
azsaqib
I have a stair with 24 risers from Ground Floor to First Floor. But when it reach to First Floor its waist slab is not joint with bottom of slab properly. Kindly see attached image & suggest the solution.Thanks.
Wed, Dec 18, 2013 at 3:05:33 PM | Stair not joining first floor slab properly
Typically we set a stair up like that to end with a tread.
Floor slab edge not joining right REV2008
Tue, Aug 14, 2007 at 3:37:07 AM
monolithic stair join at floor slab
Wed, Sep 24, 2014 at 11:30:35 AM
Properly showing slab edge in section.
Mon, May 3, 2010 at 5:27:10 PM
Stair visible through floor
Thu, Feb 5, 2009 at 5:21:21 PM
Wall top vs. First floor slab
Thu, Jul 8, 2010 at 10:40:55 AM
Page generation time: 0.3805
