Forums >> General Discussion >> Revit Project Management >> Incorporating a Spot elevation tag into a custom made pipe "size" tag
Fri, Dec 13, 2013 at 8:00:11 AM | Incorporating a Spot elevation tag into a custom made pipe "size" tag
Pikachu123
  • i'm trying to incorporate a spot elevation tag into my custom pipe size tag
  •  i can incorporate a invert elevation parameter into it, but it doesn't take into consideration pipe thickness, therefore i have to use a spot elevation tag, and i know i;m trying to"breed" two different kind of species in Revit 14 but if i can manageto do it then i can save some serious man hours and a lot of frustration, if anyone could point me in the right directioni would greatly appriciate it.
Fri, Dec 13, 2013 at 8:12:31 AM | Incorporating a Spot elevation tag into a custom made pipe "size" tag
I don't see how you can do this.  The tag reads what the object is.  The spot elevation has to read the object after it is placed.
Fri, Dec 13, 2013 at 8:26:39 AM | Incorporating a Spot elevation tag into a custom made pipe "size" tag
Pikachu123
I see, i was thinking since my tag that i made has a handful of parameters i can use as labels in it, if there was a way i could turn that into a label, or even a workaround involving: offset(elevation)subtracting radius, then subtracting pipe thickness into a custom paramter. that i can relate between the family and the project i'm working in. does that make any sense? or even possible, just trying to save my coworkers from having to line up the spot elevation tag, turn off the leader, then place the pipe size tag. Instead trying to make it all one process.
Fri, Dec 13, 2013 at 8:28:38 AM | Incorporating a Spot elevation tag into a custom made pipe "size" tag
Pikachu123
or even if i could edit the spot elevation tag to incorporate system type and size. like a vice versa process, instead of getting he spot elevation tag to communicate with my tag, just incorporate the information from my tag into the spot elevation tag. ya know?
spot elevation & custom pipe tag
Mon, Mar 24, 2014 at 10:29:52 AM
Invert Elevation Vs. Spot Elevation
Mon, Apr 20, 2015 at 2:09:11 PM
Spot elevation Tag and Insulation
Wed, Jun 11, 2014 at 10:00:27 AM
Changing the size of the interior elevation tag
Wed, Dec 20, 2006 at 12:26:41 PM
Custom elevation tag
Sun, Oct 3, 2010 at 7:35:54 AM
Page generation time: 1.2174
