Forums >> Revit Building >> Technical Support >> Phase filter problem
Thu, Dec 12, 2013 at 7:50:20 PM | Phase filter problem
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Hey, I'm designing an addition to a school which we have the original plans for, and so we've as-builted and reconstructed the existing building fromthe old mylar set in pretty good detail.  But now, in Revit, i want to show the phasing, with new construction in black and white, and existing in gray, like typical.  However, after removing the the solid gray hatch from the phase filter defaults, it appears that detail level for non-current phases is locked at coarse...?
How can I change the settings for past phases so that details such as wall layers are not obscured, with the only distiction being cut/projection line weight and color?  It's looking like there isn't a way.
Revit design suite premium 2014.
Edited on: Thu, Dec 12, 2013 at 8:00:12 PM
Fri, Dec 13, 2013 at 5:39:14 AM | Phase filter problem
The thought process is that previous phases are complete.  There are no seperate layers now, it is a wall and all you see is the exterior.
Filter by Phase
Thu, Apr 15, 2010 at 10:37:34 AM
Phase Filter
Thu, Mar 29, 2012 at 7:54:11 AM
R-17 Wanting to change the phase filter setting in a Walk Through......
Tue, Jan 3, 2017 at 11:07:39 AM
Filtering a phase that you have created
Tue, Dec 5, 2006 at 8:34:41 PM
Future Phase
Tue, Sep 9, 2008 at 2:18:29 PM
Page generation time: 1.8684
