27 Users Online (25 Members):
Forums >> Revit Structure >> Technical Support >> Pénétration buses PVC dans un batiment béton
1 Posts No Rating |
bonjour à tous,
voici mon 1er post... J'espère que je n'ai pas tronqué la procédure, bref!
REVIT MEP 2013 en ANGLAIS pouawww!!! pas le choix-------> grand groupe   francais)
Je souhaiterai faire pénétrer des buses PVC dans un batiment béton. J'ai donc créer des 'pipes", mais je n'ai pas l'impression que les murs du batiment soient réellement percées!!!!.
Si une âme charitable veut bien me donner un conseil, je suis preneur.
Bonne journée à tous
You'll have to write in English if you want to get some help.
1 Posts No Rating |
SORRYYYYYY!
I would like to install PVC pipes into a concrete wall. I create these pipes but I do not feel that the holes in the wall are made.
Thanks for help.
Best Regards
I assume you want a hole in a wall created by sometnig like a cast in pipe sleeve. I believe you are correct. Piping does not cut holes in walls. If you really want to model that, you would have to have a family that is hosted and cuts the host. There is a pipe sleeve family here in downloads http://www.revitcity.com/downloads.php?action=view&object_id=6721 This family would have to be placed separately from the piping.
i had gotten this error message |
Mon, Aug 30, 2010 at 5:19:50 PM
looking for LIGHT TRAIN (LRT) and CITY BUSES |
Sun, Apr 7, 2013 at 9:28:25 AM
PVC Conduit Family |
Wed, May 6, 2009 at 11:23:23 AM
Revit 2013 Systems |
Tue, Oct 9, 2012 at 12:45:22 PM
Rendering Accurate Colors |
Tue, Oct 25, 2011 at 9:44:50 AM
