Forums >> Revit Building >> Technical Support >> Roof Overhang Dimensional Issuse
Wed, Dec 11, 2013 at 2:24:01 PM | Roof Overhang Dimensional Issuse
GHAYSLET
I use Revit 2014, and I am having an issue with roof overhangs and stacked walls.  For some reason, my overhangs are all being ofset from the centerline of the wall when it is a stacked wall.  I am not using extend to wall core or anything like that, and it works fine on basic walls.  After a lot of experimenting, I found that TAB will let you choose the exterior face as you are picking the wall, but it is not the most reliable method and I have some Revit beginners working with me.  Is there some kind of setting somewhere that can help me out?
Wed, Dec 11, 2013 at 3:08:25 PM | Roof Overhang Dimensional Issuse
When I tab select the upper wall in my stacked wall, the roof overhang goes to the exterior.  When I pick the stacked wall, it goes to the center (I believe it is really the location line of the stack).
Roof Overhang extension
Fri, Feb 3, 2017 at 8:20:07 PM
can't adjust roof overhang
Mon, Feb 16, 2009 at 12:12:59 PM
unable to add roof overhang
Tue, Mar 8, 2011 at 1:15:32 PM
Flat roof Overhang with profile
Tue, Apr 13, 2010 at 9:59:56 AM
changeable Overhang thickness
Mon, Oct 8, 2012 at 5:02:32 PM
Page generation time: 0.2751
