20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Horizontal section
Is there a simple way to make an horizontal cut and hide everything up this plane??
A part of the previous question: is there a way to hide part of a stair ???
as always thanks
A horizontal section would be a plan?? So yes...
If this isn't acceptable you can create a detail section at any angle.
A stair will always show the extended element above the cut dashed. This is a system property that i don't think can be changed.
If its that critical i'd place a filled region over it to block the unwanted section.
90 Posts No Rating |
You can also put 'plan region' and define view range for that plan region specialy to see or hide something
well, of course the question wasn't very clear.
what I want to do is to cut in a camera view, with the object to make 3d view of 1st floor, without having to modify all that is over it. (hide elements is not enough, as i want to cut walls at 1,5m, for example). It is an horizontal section, but not to be seen on plans, but in 3d views.
it is a bit clearer?? I hope so...
You have to use the Section Box.
In the 3d view, left click, Properties-> and check Section Box.
Hope it helps.
that one was the order I was lookin for,eepa!
thanks to all anyway.
HORIZONTAL SECTION |
Wed, Apr 7, 2010 at 5:49:36 AM
Horizontal section references on elevations |
Tue, Jul 31, 2012 at 3:25:32 PM
14
Curtail wall on Sloping mass - mullions to be horizontal |
Wed, Apr 24, 2013 at 10:01:29 AM
callout annotation in section w/ coresponding section anno in plan |
Mon, Sep 24, 2007 at 1:33:19 PM
custom section head rotation (2019) |
Fri, Dec 14, 2018 at 9:28:45 AM
