Forums >> General Discussion >> Revit Project Management >> Laboratory Casework
Wed, Dec 11, 2013 at 9:41:06 AM | Laboratory Casework
AVig
Anyone have experiance with using manufaturer's families such as Fisher Hamilton? Their library is very thorough but also very hard to navigate because they use the product numbers as the family names and have a huge type list. Any advice?
Wed, Dec 11, 2013 at 10:14:21 AM | Laboratory Casework
I am using them on a project now.  Yes, their type list is huge and a little hard to follow at first but they are quality Revit families.   Just copy to your system the base family and the type catalog then load your families into the project from there.
I have a PDF of their catalog open seperatly so I can determine the number I need.
Edited on: Wed, Dec 11, 2013 at 10:15:19 AM
Wed, Dec 11, 2013 at 10:33:10 AM | Laboratory Casework
AVig
Do you edit their families at all or just use them as is? One thing I'd have to do is edit them to show up dashed below the countertop. How easy would it be to re-name their type list into something more user friendly, can you just edit the txt file? I'm embarking on bringing our lab specialty company into the world of Revit....UGH!
Wed, Dec 11, 2013 at 10:43:44 AM | Laboratory Casework
AVig
Wed, Dec 11, 2013 at 11:10:28 AM | Laboratory Casework
Don't alter the families!  Use the built in hidden lines tool in Revit.
Click on view / show hidden lines.  In the lower left corner, Revit will instruct you "First Pick - Select item to show hidden lines through" - in this case your counter.  Now in the lower left corner Revit will ask you to pick the item to show as hidden BUT before you do that check the multiple selection box on the options bar.  Pick all of the base cabinets you want to show and then double click out in space.
Sometimes there is a BUG here that doesn't seem to let you finish the process.  In that case I start a new command like view section then I hit escape.
Wed, Dec 11, 2013 at 2:08:36 PM | Laboratory Casework
AVig
Thanks! I think I've only used that tool once.
Phantom Casework
Tue, Aug 28, 2012 at 12:25:48 PM
Casework below countertop not visible.
Wed, Jan 27, 2010 at 2:16:58 PM
Lower casework showing through when touching counter?
Wed, Mar 6, 2013 at 9:38:23 AM
Capturing room number and name data for casework, furniture, etc.
Tue, Sep 20, 2005 at 8:45:55 AM
Casework Graphics
Thu, Aug 18, 2011 at 3:53:04 PM
Page generation time: 1.3945
