Forums >> Revit Building >> Technical Support >> New fill pattren
Fri, Feb 17, 2006 at 9:08:25 PM | New fill pattren
carlosgt
How do you create a new fill pattern for a wall or roof, from scratch? If I create a new hatch in Autocad, Can i take it to revit? Thanks.
Mon, Feb 20, 2006 at 10:32:18 PM | RE: New fill pattren
eldados
eldados Avatar
4.5 Stars: 8 Votes
you can create what ever pattern you want using a: 1. text file, if you know what you are doing, and save as .pat and import to revit 2. a third part program (can't remember the name) and import into revit
Integrator
KarelCAD
Tue, Feb 21, 2006 at 1:37:40 PM | RE: New fill pattren
carlosgt
what "if you know what you are doing" means? How do you create a pattern from a text file?. Do I have to draw the pattern in the text file? That sounds a little crazy. help...
Tue, Feb 21, 2006 at 4:19:16 PM | RE: New fill pattren
arccodex1
3 Stars: 1 Votes
Someone suggested this software: http://www.cadopolis.com/autocad_addons/GlobalCAD_Hatch-Manager.shtml We use HatchKit: http://cadro.com.au/hatchkit/index.html
Tue, Feb 21, 2006 at 5:16:05 PM | RE: New fill pattren
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
help...
if you open a pat file in notepad for example, you'll see that its all stored as co-ordinate data. That's why eldad say "if you know what your doing" as its a little tricky...
Post edited on 2006-02-21 17:16:37
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:36 AM
Fill Region Not Showing
Wed, Aug 22, 2018 at 5:28:47 PM
Revit 2009 - Fill Patterns
Sun, Nov 21, 2010 at 9:17:43 AM
fill pattern and line style
Thu, May 5, 2005 at 6:25:07 PM
Solid Fill Hatch
Sun, Apr 1, 2007 at 8:56:31 PM
Page generation time: 0.6538
