Forums >> Revit Building >> Technical Support >> images are showing area surface patterns through them
Tue, Dec 10, 2013 at 3:12:36 PM | images are showing area surface patterns through them
JoshSwear
I work for a company that wants surface patterns in each enclosed area. They also want logo's put on these areas. When I place the images in any format in the drawing they will not show up clearly in the drawing and all white areas of the images show the area color through them. It makes for fuzzy hard to read logos. The only solution I have found so far is to change the area transparency to the images appear through them but I am looking for other options to get the best looking final product...Thoughts?
Tue, Dec 10, 2013 at 3:15:24 PM | images are showing area surface patterns through them
How are you placing your images, as a decal?
If the image has been modified to set the background to transparent, then that would cause your problem.
Tue, Dec 10, 2013 at 3:20:46 PM | images are showing area surface patterns through them
JoshSwear
no we have the images as jpegs brought in not as decals. we set up parameters for area boundries so that the surface patterns are a solid fill, those we had to make somewhat transparent so that the images showed up at least a little. I couldnt get the decals to show up all the time so I didn't use those in floor plan view.
Tue, Dec 10, 2013 at 3:40:41 PM | images are showing area surface patterns through them
Images inserted in this manner will be by default set to background and all model elements will be in front of it.  If set to forground, all model elements will be hidden.
Maybe you need a different process.  Decals will work but you need a host.  That probably means a floor which you may not have had.  If the decal is in a seperate workset, then that can be controlled.  Decals will also show in 3D views.
Surface patterns
Thu, Jan 31, 2013 at 9:11:08 AM
Surface Patterns in Perspective
Fri, Jan 27, 2012 at 7:04:34 AM
Surface Patterns
Wed, Mar 4, 2009 at 11:24:15 AM
Existing Phase Surface Patterns visibility
Tue, Nov 14, 2006 at 6:37:24 PM
materail surface patterns
Fri, Jun 13, 2008 at 8:06:11 AM
Page generation time: 1.5837
