Forums >> Revit Building >> Technical Support >> Hiding Level Bubbles to internal elevations
Tue, Dec 10, 2013 at 1:27:15 AM | Hiding Level Bubbles to internal elevations
bsf
Hi,
Using Revit 14.
For internal elevations we usually turn off the level bubbles for all but the left most elevation.  i have been trying to make this the default in the View Template though the only thing I can find is the Level,  not the bubble.  Any ideas would be very welcome.
Attached is part sheet showing elevations as they are inserted,  and below how we would like them to look.
Regards
Brent
Tue, Dec 10, 2013 at 7:36:12 AM | Hiding Level Bubbles to internal elevations
You will have to indiviually turn them off.
Tue, Dec 10, 2013 at 7:36:29 AM | Hiding Level Bubbles to internal elevations
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can't turn off a level head in visability graphics, only under the level type
Tue, Dec 10, 2013 at 4:10:45 PM | Hiding Level Bubbles to internal elevations
bsf
Thank guys.  Appreciate your help.
Elevation lines and bubbles on sections and elevations.
Thu, Aug 30, 2012 at 2:05:14 PM
Interior Elevations - 4 callout bubbles combined to single callout bubble?
Wed, Jul 10, 2013 at 5:08:00 PM
Which is better? (For repeating same elevation level heights)
Fri, Jan 11, 2008 at 10:00:30 AM
Level elevations
Thu, Sep 11, 2014 at 12:54:39 PM
Callout Detail Occurs @ Multiple Locations. Anyway to place detail bubbles...?
Thu, Jan 21, 2010 at 9:02:50 AM
Page generation time: 2.8966
