Forums >> Revit Building >> Technical Support >> Controlling Line Weights with Filters
Mon, Dec 9, 2013 at 2:56:18 PM | Controlling Line Weights with Filters
grid
I am using Revit 2014 and am having trouble controlling wall lineweights by using filters to control varying wall types/finishes in a view. I have a few different walls that stack to create a single assembly in this project. For example, I have a CMU wall assembly, a metal stud 'furring' wall and a tile finish each as seprate wall types.
When I apply my filter and select and apply the 'cut' lineweight override I am not getting a uniform application. Some lines follow the filter override while others are using the defualut wall cut weight. In the image below I have the furring wall assemly set to lineweight 3 and the tile finish as lineweight 2. You can see that lines on each of these are still being displayed at a much heavier weight.
How do I get the filter to apply to all lines on the wall type? Hopefully the attached reference image helps. Thanks in advance!
Palm Springs Architect using Revit LT!
Tue, Dec 10, 2013 at 7:26:18 AM | Controlling Line Weights with Filters
You do understand that there are only two linetypes that you can control for walls, correct?  Only the exterior line and for medium and fine views, all interior lines (common edges) are one setting.  That's it.  When you place one wall type against another, there is no "common edge" between them, it is an exterior line for each wall.
Tue, Dec 10, 2013 at 11:39:41 AM | Controlling Line Weights with Filters
grid
I was thinking my filter overrides would modify the lineweight for the whole wall regardless of whether it is an exterior line or interior line.
Your mentioning that makes sense because it is the exterior lines that are displaying too thick. How do I go about modifying the weight of the exterior lines? Is there a way to control them with the filters as well?
Thanks for your wealth of knowledge WWHub.
Tue, Dec 10, 2013 at 11:53:50 AM | Controlling Line Weights with Filters
You can not control these in any automatic way.  For these now "interior lines", you would have to use the linework tool in your views and you have to do that for each wall - two lines in the same place.
Lineweights For System Filters
Mon, Apr 20, 2015 at 2:28:08 PM
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
A Nice set of Revit Line Weights
Wed, Jun 20, 2007 at 8:47:36 PM
exterior elevations and line weights
Fri, Jul 20, 2007 at 12:06:07 PM
Page generation time: 6.8286
