Forums >> Revit Building >> Technical Support >> Face Based Family - Reference Plane Extension
Mon, Dec 9, 2013 at 10:38:41 AM | Face Based Family - Reference Plane Extension
adthompson
Revit 2013
I am working on families in R2013 and have come across an issue new to me.  I have started using face based families in an attempt to simplify production.  The issue I am having is that my reference planes seem to ambigously extend, and I want to know how to control the extents.  When I try to dimension to a family the reference plane will extend beyond the family, which is not something that had happened when I was creating generic non hosted families.
I see that the reference planes have a "scope box" drop down, is that something I can use to trim the planes down?  Basically I only want the reference plane to show where the 3D model is, not beyond.  I hope this doesn't come off to confusing but if this is rediculously unclear I'll add a few screen captures.
Thanks, Andy
Mon, Dec 9, 2013 at 12:51:46 PM | Face Based Family - Reference Plane Extension
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Have you tried playing with the 'Is Reference' properties of the reference plan ?
Mon, Dec 9, 2013 at 1:00:57 PM | Face Based Family - Reference Plane Extension
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You may also want to try using reference 'lines' rather than 'planes'.
Tue, Dec 10, 2013 at 9:13:36 AM | Face Based Family - Reference Plane Extension
adthompson
It seems to work to use lines instead, but it's not ideal, I like planes so I can dimension from any view and not have family geometry get in the way.  FYI attached is a screen capture of the issue.
Andy
changing type of a family from wall based to face based
Wed, Mar 3, 2010 at 8:24:37 PM
How would you modify a family from face-based or hosted to one that is not?
Mon, Sep 26, 2011 at 8:39:50 AM
Locking reference plane to wall face
Fri, Jan 11, 2008 at 8:59:17 AM
Face-Based Sinks on Countertops
Fri, May 13, 2016 at 12:14:08 PM
Plan annotations for face based families
Tue, Feb 8, 2011 at 8:59:45 AM
Page generation time: 2.9488
