Forums >> Revit Structure >> Technical Support >> How to show top reinforcement hidden?
Mon, Dec 9, 2013 at 3:53:53 AM | How to show top reinforcement hidden line?
imrankhan
As per our company standers the top reinforcement should be in hidden line but revit does not give me hidden line in top reinforcement in my GA plan. other thing is how their isn't an option of additional bars....how can we designate bars as top add' or bottom add'. Thanks
Edited on: Mon, Dec 9, 2013 at 7:57:12 AM
Mon, Dec 9, 2013 at 1:30:09 PM | How to show top reinforcement hidden?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I don't think 'area' reinforcing shows up in plan at all. Never has. Not sure why.  Additional rebar does however. The only control over the linetype is in the object styles. When you add the rebar you can specify whether it's upper or lower but you cannot differentiate the linetype between upper and lower.
Tue, Dec 10, 2013 at 3:46:24 AM | How to show top reinforcement hidden?
imrankhan
Yeah if we change line type to hidden line it changes both top & bottom rebars to hidden lines which isn't a solution.......well regarding designation of top add bars could u please tell me how to designate bars like T12-150 Top add instead of default showing T12(3000)@150 Top. in properties it gives only top or bottom option.
Edited on: Tue, Dec 10, 2013 at 3:47:51 AM
path reinforcement tag and symbols
Sat, Dec 7, 2013 at 12:16:36 PM
Extent of Area reinforcement symbol
Wed, Sep 23, 2009 at 6:23:43 PM
Rebar/Reinforcement Scheduling Area Reinforcement
Wed, Mar 9, 2011 at 4:59:36 PM
Diaphragm wall reinforcement and polystyren
Thu, Aug 6, 2015 at 2:29:03 PM
Hello structural guys!!!
Sat, Dec 7, 2013 at 12:44:30 PM
Page generation time: 1.1179
