Forums >> Revit Building >> Technical Support >> Guest User vs. administrator
Fri, Feb 17, 2006 at 4:20:24 PM | Guest User vs. administrator
Formfunction33
How do I change the settings on my computer to allow the guest to use revit...I am the administrator, but don't draft formm this user...i draft as "guest" but Revit is not accessible unless i log in as the "administrator".?
Sat, Feb 18, 2006 at 6:07:27 PM | RE: Guest User vs. administrator
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What do you mean by its not accessible? Do you mean there is not shortcuts? You can simply navigate to the Revit.exe file and create a shortcut to it manually...
REVIT export to DWF
Wed, Oct 7, 2009 at 4:18:36 AM
Where do I post job openings
Thu, Feb 21, 2013 at 3:02:39 PM
Revit & Vista
Wed, Feb 27, 2008 at 7:02:00 AM
REVIT Job - BIM Specialist - Cedarglen Homes - Calgary Alberta
Thu, Jul 5, 2012 at 4:28:27 AM
How can we improve?
Sun, Dec 7, 2003 at 8:29:07 AM
Page generation time: 0.0973
