Forums >> Revit Structure >> Technical Support >> Thickened Slab not joint properly
Sat, Dec 7, 2013 at 2:13:06 PM | Thickened Slab not joint properly
azsaqib
Please see the attach files and help why the slab edge  CryingTS1 Detail) are not join properly. Thanks
Mon, Dec 9, 2013 at 7:58:10 AM | Thickened Slab not joint properly
In order to have any sweep in Revit join properly, it needs to be done in a series, not seperate sweeps.  Remove your independent sweeps then click on the one remaining and add edges to that to create the rest of the sweep.
Wed, Dec 11, 2013 at 3:18:54 AM | Thickened Slab not joint properly
azsaqib
i did not use sweep command here it is slab edge................i don't know how to use sweep for thickend slab in project neither i find sweep tool in my project. Can you Please guide me how to do that. Thanks
Wed, Dec 11, 2013 at 7:18:45 AM | Thickened Slab not joint properly
A slab edge IS a sweep, so is a cornice.  They use the sweep process but in a pre-set fashion.  Use the slab edge and do as I suggested - one operation, not multiple.
Rebar in a thickened slab Revit 2012
Thu, Dec 29, 2011 at 6:40:29 AM
Thickened slab appearance
Fri, Jun 8, 2012 at 10:43:23 AM
Thickened Slab Not Cutting Floor Line Out
Wed, Dec 28, 2011 at 7:54:13 AM
Modeling thickened slab strip under bearing walls
Thu, Feb 5, 2015 at 1:13:00 PM
Thickened slab at stoops
Sun, Sep 25, 2005 at 6:39:41 PM
Page generation time: 0.7988
