17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Pop up videos problem
0 Posts No Rating |
Hi everyone,
I have Revit 2014 and I have a problem when the video meant to show how a tool is working (for example, the one that pops up when you let the mouse on the Modify roof's sub elements tool) is loading.This video remains ever after until I close the software, repeating itself endlessly.
How could I fix this problem? Either cancel this helping function or make it function properly (I suppose it should close itself automatically).By the way, I have the same issue with autocad 2014. (it appears when the video explaining 3d modeling Blend, Patch, Offset is loaded. Impossible then to close the window poping up and which shows the way to blend, patch or offset a 3d surface...)
Thank you for your answers!
0 Posts No Rating |
I've had strange graphical issues with 2014 also, though not what you experience. I've read that there may be issues with NVidea cards / drivers. Could that be what is causing the problem?
I think that was a bug they fixed in a service pack or hot fix ??
I used to get the 'permanent imprint' branded on my screen. Couldn't get rid of it wiithout shutting down REVIT. Very annoying. Haven't had it happen in a long time.
It's always worth playing with these switches as well.
grant permit request doesn't pop up |
Tue, Aug 1, 2006 at 1:27:31 PM
New Revit Videos on YouTUbe |
Sat, Oct 17, 2015 at 4:26:02 AM
some pop-up menus do not appear |
Wed, Jun 7, 2017 at 5:37:40 AM
NEED A POP DISPENSER |
Fri, Oct 20, 2006 at 10:15:39 AM
Revit 2014 SHEETMASS ZERO pop up issue |
Wed, Apr 30, 2014 at 2:55:49 PM
