Forums >> Revit Building >> Technical Support >> How can i lock the floor and walls to NOT change it's size automiticaly?
Sun, Dec 1, 2013 at 3:54:47 PM | How can i lock the floor and walls to NOT change it's size automiticaly?
danezeq
this question cannot be understood without this video i made:
http://www.youtube.com/watch?v=V_5_vNByEG8
thank you all :-)
Mon, Dec 2, 2013 at 7:43:37 AM | How can i lock the floor and walls to NOT change it's size automiticaly?
Please add your question.  You should have posted your question first here and used the video to clarify it.  Asking the question afterwards just doesn't work.
Mon, Dec 2, 2013 at 7:56:05 AM | How can i lock the floor and walls to NOT change it's size automiticaly?
danezeq
My question is How to lock the floor and other walls to NOT change its size when i change the type of the wall, to one with external layer (wood layer in this case).
I want the floor and walls to stay exactly how they were. i don't want them to change in size when i change the wall type  to a thicker one.
i hope it was understandable. quite difficult to phrase..
Edited on: Mon, Dec 2, 2013 at 8:08:59 AM
Mon, Dec 2, 2013 at 8:28:25 AM | How can i lock the floor and walls to NOT change it's size automiticaly?
If you change a layer thickness then the wall will obviously change size. 1+1+1 = 3, 1+1+2=4 Simple math.
If you want the wall to stay the same overall thickness then you must subtract the difference elsewhere.
Are you sure your question is not really about wall location?  You can change that so the wall says in the same relative location.
Mon, Dec 2, 2013 at 8:30:44 AM | How can i lock the floor and walls to NOT change it's size automiticaly?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Align and lock the floor to the inside face of the wall, then the floor will stay attached to the inside face of the wall so if you placed your wall correctly and make it thicker it will extend the exterior face of the wall out and not move the inside face.  Also if you have the same wall type going from first floor to second floor why do you have to separete walls, just make them one wall.
"Are you sure your question is not really about wall location?"  WWHub beat me to it and this is more of what your problem is than your wall thickness.
Edited on: Mon, Dec 2, 2013 at 8:31:56 AM
Mon, Dec 2, 2013 at 2:06:06 PM | How can i lock the floor and walls to NOT change it's size automiticaly?
danezeq
WWHub, i'm not talking about the wall thickness. the one wall i changed it's type will obviously be thicker...
i'm talking about the size of the FLOOR, and the LENGTH of the other walls which suddely changed.
Mon, Dec 2, 2013 at 2:17:22 PM | How can i lock the floor and walls to NOT change it's size automiticaly?
danezeq
ok forget about the length of the walls - it's my misunderstand i think... i problem stays the floor.
Mon, Dec 2, 2013 at 2:23:03 PM | How can i lock the floor and walls to NOT change it's size automiticaly?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The problem is your wall location as WWHub stated.  When you make the wall thicker it is pushing out and your floor is following it.
Mon, Dec 2, 2013 at 2:23:46 PM | How can i lock the floor and walls to NOT change it's size automiticaly?
"... i problem stays the floor....."   ? Huh?
If your wall intersects the floor and your wall and floor layers are correct, you can join the two objects and one will cut the other according to the layer function.
Please read this topic in your HELP:
"Applying a Function to a Layer of a Compound Structure"
Mon, Dec 2, 2013 at 2:34:29 PM | How can i lock the floor and walls to NOT change it's size automiticaly?
danezeq
I mean: My problem stays the floor. sorry for that.
my problem is still that the floor change its size in accordiance with the wall.my goal is that the floor will stay in exactly the same size.
Mon, Dec 2, 2013 at 2:39:29 PM | How can i lock the floor and walls to NOT change it's size automiticaly?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Again.. WALL LOCATION LINE.  Set yours to be finish face interior
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-F26DB6DA-A0EC-424D-B656-3BDF47607F4F
How to lock walls so they move together
Tue, Dec 21, 2010 at 12:45:46 PM
Can't Change Stairs In Floor Plan Without Other Flloor Plans Changing As well
Wed, Dec 25, 2024 at 7:45:36 PM
Help with a single stone moulding window
Thu, Aug 18, 2005 at 3:31:42 AM
REVIT PROMPT: Would you like walls to attatch to this floor's bottom?
Sun, Apr 24, 2011 at 9:25:55 AM
I can't change the connecor size. It stays on -609.6 mm
Mon, May 18, 2015 at 7:06:40 AM
Page generation time: 6.1959
