Forums >> Revit Building >> Technical Support >> Rooms Areas For Large Hotels
Fri, Nov 29, 2013 at 12:18:01 PM | Rooms Areas For Large Hotels
Reddrev
I am designing a hotel with 5 types of room (and sizes) the usual, Standard Deluxe ,Superior, Exec...  etc.   In Total about 800 rooms.  I inetend to group each type and populate it throughout the hotel.
To make a schedule and have the room tag listing the room / key number, do I have to place each area for each room, or can this be done in the actual group and thus automatically replicated?
I have done some tests and it seems the values of each grouped room are scheduled and listed as 1, 2, 3 ,4 etc, but the room tags are missing in the plan views.
Or is there another way I should be doing this?
Many Thanks
Mon, Dec 2, 2013 at 8:04:09 AM | Rooms Areas For Large Hotels
Watch out!  Groups are great but you need to learn what you should and should not include.   Items that will change need to be removed from the group - otherwise every instance has to be modified on every change - not just at the end of the edit.
For schedules, we only use one room from each type.  All other rooms are set not to be scheduled.  The same for interior room doors.
Schedule Rooms Within areas of a specific area plan
Mon, Nov 25, 2013 at 12:59:18 PM
Deleting Rooms from Schedules
Tue, May 8, 2012 at 8:30:32 PM
Large scale projects with repeating rooms grouped...
Wed, Jul 25, 2007 at 8:48:42 AM
Rooms!!!
Wed, Dec 12, 2012 at 12:24:13 PM
Many Small Groups OR Few Large Groups
Mon, May 12, 2014 at 9:59:30 AM
Page generation time: 3.0223
