12 Users Online (10 Members):
Forums >> Revit Systems >> Technical Support >> Void extrusion family visibility
5 Posts No Rating |
I have a family of windows into which I want to load a family with a void extrusion with a visibility parameter so that I can determine whether it cuts into the host wall or not. The idea is to have a cavity beneath the window for a radiator in some types.
For this purpose, following some suggestions from here, I created a void extrusion family that starts outside of the host and then cuts into it depending on the yes/paramenter - with a formula which controls the depth. However, while this works perfectly inside the family of the void extrusion itself, as soon as I load it into the window family and attempt to turn it off, it says that the instance is not cutting anything and asks to delete it. How can I solve this?
just make another small cut which always cuts host.
http://youtu.be/R88BMsX3A5w
hope it helps.
want more?
You can get more tips at Enjoy Revit |
I downloaded this sink from Corian. The void extrustion is cutting into my vanity front panel and is showing in elevation and the void is showing in section. How can I make the void not cut the vanity and also not show in section?
Does this help? https://atgusa.com/revit-2021-new-feature-void-visibility-control/
I read that before I posted and it didn't help. Thanks anyway. I ended up using masking and filled regions to fudge the sections and elevations for now until I can fix it properly.
If it is just a simple rectangular void extrusion there is no need to make it a separate family. If you make it in the window family itself using reference planes to control its lenght and height and then assign a yes/no parameter to the 'cuts geometry' attribute it will work.
Then as long as you have the void always be intersecting the wall/host you will not get the error msg.
Void Extrusion in window family problem |
Mon, May 18, 2015 at 3:55:23 PM
void extrusion not cutting solid extrusion |
Fri, Oct 10, 2008 at 3:47:43 PM
Make void extrusion permanent |
Wed, Feb 9, 2022 at 6:46:57 PM
Void Extrusion Constraint |
Tue, Apr 11, 2006 at 9:03:58 PM
Void Extrusion |
Tue, May 28, 2013 at 8:15:38 PM
