8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Demo shapes from existing walls
We are trying to demo shapes within an existing wall with no luck...
We've tried:
In-Place Families
Opening Tool
Door Opening Families
Edit Profile w/ Infill
Any suggestions would be appreciated.
Here is the file
Accidentally deleted Materials trying to make this file smaller. Let's try this one more time.
Hmmm, Using an external family either:
Generic model wall hosted template-->opening OR
Door-->opening
It displays fine in all views except for the 3D... Here it appears to lose its edges where the opening is created. I wouldn't have thought the 3D side of things would be as critical so this would be my preference.
I suggest you send this information off to Autodesk support so they can resolve the issue.
HTH.
Maybe you can post your solution. I've tried Generic model wall hosted template-->opening AND Door-->opening. Boundaries still don't show in the South Proposed Elevation or 3D view as you mentioned.
Looks like the Edit Profile Tool with an infill wall is working better. It still requires some cleanup though.
Post edited on 2006-02-16 20:26:43
existing, demo and new roof |
Wed, May 28, 2008 at 8:21:30 AM
How Do I Create Existing and Demo Floor Plans From Linked Model |
Thu, Dec 20, 2012 at 9:20:06 AM
Phasing Setup |
Tue, May 15, 2012 at 1:29:05 PM
New Door Cuts in the Demo Plan |
Wed, May 22, 2013 at 3:21:44 PM
Walls set as existing not showing up in existing phase settings. |
Sat, Aug 4, 2012 at 11:21:58 AM
