Forums >> Revit Building >> Technical Support >> Lights in Rendering behaving badly
Wed, Nov 27, 2013 at 1:29:44 PM | Lights in Rendering behaving badly
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Has anyone encountered this problem before (attached)? I inserted a family from a lighting manufacturer and the IES file that was part of it seems to be making Revit throw up....a bad render output.
Wed, Nov 27, 2013 at 2:21:50 PM | Lights in Rendering behaving badly
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Some initial research shows that there has been an issue with IES files in Revit and that it has to do with Absulte IES files:
http://forums.autodesk.com/t5/Revit-Architecture/Problem-rendering-when-using-an-quot-Absolute-quot-IES/td-p/3120130
Has anyone been successful editing the IES file and then rendering in Revit the way it was done in the linked article?
Thu, Nov 28, 2013 at 8:31:07 AM | Lights in Rendering behaving badly
4 Stars: 205 Votes
I saw this problem once, I believe you can solve this if you "Play" with "Adjust Exposure".
Thu, Dec 12, 2013 at 6:57:19 PM | Lights in Rendering behaving badly
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I'll give that a try!
Tue, Dec 17, 2013 at 6:33:19 PM | Lights in Rendering behaving badly
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I still haven't had any luck here. Seems like all ies files are creating problems in Revit rendering environment. Does this work in 2014? I;m still running 2013 until january.
Fri, Aug 29, 2014 at 4:55:33 PM | Lights in Rendering behaving badly
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Any new insights on this? Do IES files work at all in Revit renderings? So far all I ever see are rainbows from the lights. Enlighten me!
rendering: can't get itnerior lights turned off
Mon, Feb 27, 2012 at 6:14:44 AM
lights not working in 3D or rendering
Thu, Jul 11, 2013 at 10:56:36 AM
Exterior night rendering with interior lights on? R16
Wed, Aug 3, 2016 at 1:23:36 PM
artificial lights not rendering
Tue, May 7, 2013 at 6:52:56 AM
Interior rendering with lights
Wed, Sep 29, 2010 at 8:50:38 AM
Page generation time: 0.1680
