Forums >> Revit Building >> Technical Support >> Any way to cut an in-place roof?
Fri, Nov 22, 2013 at 6:19:01 PM | Any way to cut an in-place roof?
Hybrid
Revit 2012
I've been trying to figure this out for ages. I know an in-place void will cut a roof extrusion (from the roof tab) but I can't seem to get any void to cut any in-place roof.
The dormer I want is not a half circle, but slightly stretched (elipctical) and slopes a bit. So rather than an extrusion I did a blend. If there are better ways please do share.
Here are images of a quick setup just to show what I want accomplished. I'm really thinking I'm missing something obvious here.
Thank you in advance
Mon, Nov 25, 2013 at 1:57:06 AM | Any way to cut an in-place roof?
ronmalit
5 Stars: 3 Votes
hi
i dont know why this thread is unanswered.
if this is still unsolved. you must create the void inside where you created your blend.
select the in-place, edit, create void, cut the void and blend, close the in-place editor.
and also, if you used roof by extrusion... model your extrusion a bit short, then use the JOIN/UNJOIN ROOF under MODIFY tab.. no in-place void needed to achieve what you are trying to do on your images.
** dont be mad, i dont have much... i am homeless
Custom in-place Roof Voids and the disdain of Revit 2010
Thu, Aug 27, 2009 at 3:24:24 AM
Roof Fascia On Negative Sloped Roof
Wed, May 15, 2013 at 9:47:35 AM
Can't make a Two Cut - Square rafter cut on a roof
Fri, Jan 14, 2011 at 6:20:30 PM
RAC09 - Roof Fascia Corner Miter on Square Cut
Wed, May 27, 2009 at 6:57:00 PM
Cut Roof with VOIDS
Tue, May 27, 2014 at 8:01:33 AM
Page generation time: 1.1769
