Forums >> Revit Building >> Technical Support >> Using the built-in Mark parameter when tagging
Fri, Nov 22, 2013 at 2:33:14 PM | Using the built-in Mark parameter when tagging
camerongood210
This project has 100+ brackets and each of these brackets are mounted at different heights. We've shown them in the plan and we would like to create a schedule indicating each bracket's mounted height. We tried giving each bracket a unique ID in the Mark field, but we're having trouble getting that Mark ID to show up in a tag. Any thoughts?
Fri, Nov 22, 2013 at 2:39:54 PM | Using the built-in Mark parameter when tagging
camerongood210
We created these bracket assemblies as a structural framing family. We are using Revit 2013. Thanks for your help guys.
Mon, Nov 25, 2013 at 2:19:04 AM | Using the built-in Mark parameter when tagging
ronmalit
5 Stars: 3 Votes
hi.. normally, tagging mark values should not have any problem.. if you can attached both your bracket family and structural framing tag you are using, then it is better... if not, then make sure the tag is picking up the correct parameter defined in it..
another thing is,, most of revit family doesnt allow you to schedule elevation...
i have been using this toolkit and maybe you can try it, and run some testing... it will give you the x,y,z values/coordinates. but that still depends on how you have created your bracket family and your project basepoint... so pls try it.. if you cant get correct elevations, then contact them or ignore this suggestion. *** i dont work for them
Revit Toolkit
The coordinate scheduling tool, developed by Excitech for the Revit Platform will allow accurate and simple scheduling of X,Y and Z coordinates from Revit model elements. This is suitable for a whole range of applications but particularly the easy production of Piling schedules.
- See more at: http://www.excitech.co.uk/products/Revit-Toolkit.asp#sthash.nfgXMGIB.dpuf
** dont be mad, i dont have much... i am homeless
Tagging offset parameter
Tue, Jul 27, 2010 at 3:47:47 PM
Tagging items based on view
Wed, May 9, 2012 at 3:01:54 PM
Tagging & Scheduling grouped doors
Mon, Jan 21, 2013 at 4:54:37 PM
Beam Tagging
Mon, Jun 6, 2011 at 11:51:47 AM
WINDOW TAGS
Thu, Feb 13, 2020 at 12:20:54 PM
Page generation time: 0.5345
