Forums >> Revit Building >> Technical Support >> Revit 2013 & 2014 Building Design: Lookup Table and the Revit.ini file questions
Fri, Nov 22, 2013 at 9:27:55 AM | Revit 2013 & 2014 Building Design: Lookup Table and the Revit.ini file questions
jmqrsq
5 Stars: 3 Votes
I am hoping this could be a sticky for everyones future reference:
My questions are
1. Which Revit.ini file should you edit to point to a new Lookup Table network location, the user or program file version?
2. After you edit the .ini file and save it what are the steps you have to do to "refresh" the pipe fittings already loaded in my project? Is it just a simple restart of Revit or do I need to reload every affected pipe fitting family?
I have done a ton of looking around different forums and have yet to find a single thread that explains this process completely. Thanks to those in advance who can answer this definitively and I hope everyone from here on out can benefit from this thread.
PS I plan to update edits to this thread as other questions that relate pop up.
Thanks
EDIT 1: Are there any charachter limitations in a network path for the .ini file? ie. \\BIM\#Common\Lookup Tables
Edited on: Fri, Nov 22, 2013 at 9:30:50 AM
Fri, Nov 22, 2013 at 5:46:41 PM | Revit 2013 & 2014 Building Design: Lookup Table and the Revit.ini file questions
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
1) The Revit.ini is usually in the C:\Program Files\ (Revit 20... )\Program\  folder.
2) After editing the .ini file, you need to Re-start Revit. I am not sure what you mean about "refreshing the pipe fittings already loaded in the project". You are just changing the path for the lookup tables. The families will still look for the same file names, but now in a different path. There is no need to reload any families.
I don't know if that character "#" that you have in the path will cause an error.
Planta1 Revit Online Consulting | info@planta1.com
creating a part with a lookup table
Sun, Dec 24, 2006 at 8:29:35 AM
Help with lookup table and formula
Thu, Mar 5, 2020 at 4:43:58 AM
Revit INI file
Fri, Jul 1, 2011 at 12:54:47 PM
Pipe Fittings are over/under sized for connecting pipe
Tue, Jan 4, 2011 at 7:08:54 AM
Lookup Tables again
Thu, Jul 31, 2014 at 1:45:45 PM
Page generation time: 2.0539
