Forums >> Revit Building >> Technical Support >> IFC detail drawing into Revit
Fri, Nov 22, 2013 at 4:28:16 AM | IFC detail drawing into Revit
JanneMortensen
Hey all
I've downloaded the attached file, which is a detail drawing in ifc-format. I've tried to import into Revit using "Open->IFC" and "Insert from file", but nothing works. I get the following warning-message, when using the open-button: "The following problems were encountered in the IFC file: No building elements were found in the file."
Does anyone know how to open or convert this file, so that I can use it in Revit?
Janne Smile
Mon, Nov 25, 2013 at 2:31:31 AM | IFC detail drawing into Revit
ronmalit
5 Stars: 3 Votes
hi as far as i know.. you cant
ifc should be a model/objects with data/ and yes BUILDING ELEMENTS...and not a detail item.
** dont be mad, i dont have much... i am homeless
Revit MEP IFC Export - Objects not detalied
Wed, Jul 2, 2014 at 8:08:29 AM
IFC IMPORTING
Thu, Feb 23, 2012 at 5:16:29 PM
link detail drawing from another drafting view in the same project
Wed, Oct 12, 2011 at 11:14:00 AM
IFC Trouble
Mon, Sep 3, 2018 at 3:18:12 PM
Revit to Ifc to Third Party BIM Viewer
Tue, Dec 11, 2018 at 12:36:03 PM
Page generation time: 1.7294
