Forums >> Revit Systems >> Technical Support >> Scale the model?
Wed, Nov 20, 2013 at 10:04:38 AM | Scale the model?
desiiito
3 Stars: 1 Votes
Can we scale the 3d model? The building is made of panels with different slopet, there isn't walls,windows,doors, etc. Can i make to be twice smaller or i need to do it all over again? Thanks
Wed, Nov 20, 2013 at 10:49:43 AM | Scale the model?
You can't scale a model.  If components are controlled parametrically, then you can control with dimensions.
For instance, draw a box using 4 walls.  Dimesion width and length.  Click on a wall and change the appropriate colored dimension.
Export Revit to DWG - scale problem
Thu, Jul 17, 2014 at 4:35:23 PM
11
changing scale
Wed, Apr 22, 2009 at 7:01:31 AM
Large Scale Model Rendering
Tue, Oct 24, 2006 at 6:12:05 AM
Scale bar on sheet onto to display at certain scale
Wed, May 22, 2013 at 12:15:22 AM
scale image
Fri, May 13, 2016 at 1:11:44 PM
Page generation time: 0.4756
