Forums >> Revit Building >> Technical Support >> Material takeoff , Cost using both area and volume
Wed, Nov 20, 2013 at 6:13:59 AM | Material takeoff , Cost using both area and volume
ansh96
I am trying to make a material takeoff. It has some materials that are estimated using area and others using volume. How can i achieve this in same material takeoff. An example of this would be cost of Wall Core using volume and  its Surface  layers using area. Is there any way to do it ? Any help would be appreciated.
Wed, Nov 20, 2013 at 7:25:01 AM | Material takeoff , Cost using both area and volume
You might be able to but it would be a complicated schedule.  I would use seperate schedules and filter them.  We add a project parameter to all elements for use in areas like this.
Material Takeoff
Mon, Apr 27, 2015 at 7:32:15 AM
Material Volume out of Material Takeoff
Sat, Aug 9, 2008 at 7:23:48 AM
Material Cost Analysis in Schedules
Wed, Jan 13, 2010 at 6:55:37 PM
Material cost per sq ft formula
Mon, Sep 21, 2009 at 9:06:24 AM
Ceiling Material Takeoff
Thu, Feb 15, 2007 at 3:19:57 PM
Page generation time: 1.1263
