Forums >> Revit Structure >> Technical Support >> Cant exit detail component editting
Tue, Nov 19, 2013 at 2:24:54 PM | Cant exit detail component editting
Warchitect
4 Stars: 5 Votes
Help :-)
I cant get out of editing my detail GROUP (not component). See its still black and all the rest is greyed out. Ive lost where the command is to get out. escape doesnt work. I can only end the program to get out of it. where is the red X that lets me stop editing my detail group.
Edited on: Tue, Nov 19, 2013 at 2:34:10 PM
Tue, Nov 19, 2013 at 2:32:10 PM | Cant exit detail component editting
What Revit and what updates?
Tue, Nov 19, 2013 at 2:34:54 PM | Cant exit detail component editting
Warchitect
4 Stars: 5 Votes
revit 2011 and no updates...is this a known glich thing?
M
Tue, Nov 19, 2013 at 2:46:18 PM | Cant exit detail component editting
2011 has two updates that fixed issues.
In addition, if you installed 2014 (and or maybe 14), that would have messed up a dll that I know 2012 uses.
So start first by installing the 2 updates (service packs)
Tue, Nov 19, 2013 at 3:28:47 PM | Cant exit detail component editting
Warchitect
4 Stars: 5 Votes
Thanks HUB. Ill check the updates.
also just to add the go around I found.
After a restart I went to a plan view to mess with the command some more, and when i clicked edit group (in the plan view) the little pallete showed up on the field, then I picked up the pallette and set it back on the toolbar, locking it on. then went back to my elevation view and the pallete was back.
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:15 PM
Can't exit sketch mode
Tue, Oct 22, 2019 at 7:19:00 AM
Nested Annotation Family in a Detail Component
Fri, Mar 16, 2012 at 8:56:45 AM
GETTING EXIT SIGN TO MOUNT IN CEILING
Mon, Jan 25, 2010 at 10:01:23 AM
Exit sign symbol not showing in underlayed view
Wed, Jun 29, 2011 at 6:04:43 AM
Page generation time: 2.7244
