Forums >> Revit Systems >> Technical Support >> Parameter Formulas and "Grips"
Tue, Nov 19, 2013 at 12:01:19 PM | Parameter Formulas and "Grips"
setver62
Is it possible to have a parameter with a formula AND "grips"? Or is this just a wishlist item? If so, what is the process?
setver62
Tue, Nov 19, 2013 at 12:06:54 PM | Parameter Formulas and "Grips"
I don't understand how that would work.  You can have grips (instance based parameter) or you can use a formula using other parameters.
Maybe a better explanation of what you want would help.
Tue, Nov 19, 2013 at 2:55:54 PM | Parameter Formulas and "Grips"
setver62
Just want to know if you can have a formula and still get grips for that parameter. I am trying to create a parameter that uses a formula when inserted, or other parts are modified, but it can also be modified with grips. The grip modification would also feed back to the formula for final modification.
I have a face-based family (required for my needs) that needs an extrusion that stretches in 2 inch increments. If there is a way to either embed a line-based array family in the family I have, or a way for the face-based family to have this feature, that would eliminate the need for a formula.
Thanks in advance...
setver62
Wed, Nov 20, 2013 at 12:45:21 PM | Parameter Formulas and "Grips"
TKennedy
4 Stars: 8 Votes
It sounds like you need to do exactly what I did with a shelving unit family. I ended up using two parameters and two reference planes. The first parameter would be Length_Adjust, and would be tied to a the first ref plane set as a weak reference. This will give you a set of grips you can adjust in the plan. The second parameter would be Length_Actual, and would be tied to the second ref plane set as not a reference. The family geometry is tied to that ref plane. The Length_Actual parameter contains your formula, and reads Length_Adjust.
Hopefully that's clear enough for now, I don't have time to post a family or formulas.
Wed, Nov 20, 2013 at 5:18:13 PM | Parameter Formulas and "Grips"
setver62
Thanks, I'll try that.
setver62
Door Family Formulas
Fri, Dec 12, 2008 at 3:00:47 PM
instance parameter without shape handles
Fri, Aug 31, 2007 at 6:48:45 AM
"Group parameter under:"
Wed, Aug 22, 2018 at 10:42:28 AM
11
basic formula question regarding parameter use
Wed, Jun 16, 2010 at 5:34:23 PM
"can't find solutions for formulas" error
Wed, Aug 3, 2016 at 5:46:21 PM
Page generation time: 1.6050
