Forums >> Revit Structure >> Technical Support >> walls wont attach to new roof
Mon, Nov 18, 2013 at 2:21:09 PM | walls wont attach to new roof
akunkinga
I needed to amend the roof to my house model so I deleted the roof from my model.
I have now added a new roof but now the walls wont attach to the new roof
Any ideas why??
Thanks
Mon, Nov 18, 2013 at 2:27:53 PM | walls wont attach to new roof
Because your roof is not really over the walls.  Cut a section and look.
Mon, Nov 18, 2013 at 3:09:48 PM | walls wont attach to new roof
akunkinga
Hi
I am not sure what you mean. I redid the roof by picking the walls and adding overhangs, as I did with the previous roof.
Now if I look on an elevation  there is a gap between the top of the walls and the new roof
Mon, Nov 18, 2013 at 3:14:41 PM | walls wont attach to new roof
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Did you click on the wall and then tell it to attach to the roof?  It won't do it automatically unless you tell it to.
Mon, Nov 18, 2013 at 3:26:17 PM | walls wont attach to new roof
akunkinga
Yes I did that but the wall stays the same ie does not go up to the new roof
Mon, Nov 18, 2013 at 3:29:05 PM | walls wont attach to new roof
Either the roof is not over the wall or you did not attach it.
Did you edit the wall profile?  If so, then that will not attach.
Mon, Nov 18, 2013 at 3:41:34 PM | walls wont attach to new roof
akunkinga
No I didnt change anything on the walls. All I did was delete the roof (where the walls were already successfully attached before I deleted it)
Then I added a new roof by using the footprint/pick walls.
Mon, Nov 18, 2013 at 3:52:24 PM | walls wont attach to new roof
Post the section I asked you to cut perpindicular to the wall. Include the wall properties.
Mon, Nov 18, 2013 at 3:57:45 PM | walls wont attach to new roof
akunkinga
ok but I will have to wait until tomorrow as I only have software at work.
thanks so far Smile
Walls not attaching to imported roof
Fri, Aug 5, 2011 at 7:08:07 PM
Walls won't attach to roof
Wed, Nov 26, 2008 at 4:43:18 AM
Creating a roof that slopes with the walls
Sun, Feb 27, 2011 at 2:35:54 PM
How to attach top/base - walls to mass roof
Tue, Sep 22, 2015 at 3:18:05 PM
Additional Roof will not attach to original roof
Fri, Jun 7, 2013 at 7:56:40 AM
Page generation time: 0.5664
