Forums >> Revit Building >> Technical Support >> Tagging 2 rooms with the same tag/area
Mon, Nov 18, 2013 at 2:08:43 PM | Tagging 2 rooms with the same tag/area
masseya
I'm working on a project where I'm running an open corridor through a large open room and I used a room separation line to demarcate the corridor.  This splits the room in two though, and I want to tag both parts with the same tag so that the area totals up as one area.  Is there any way to do this?
Thanks,
Alan
Mon, Nov 18, 2013 at 2:26:06 PM | Tagging 2 rooms with the same tag/area
It isn't really one area - is it?
I suggest you give it a subset.... 100N, 100S or 100a, 100b or don't really take the corridor through it.
Mon, Nov 18, 2013 at 3:05:12 PM | Tagging 2 rooms with the same tag/area
masseya
We're still in pre-design moving into SD and at this point we're treating it as one space.  Our firm is just getting into using Revit for the early planning stages so we're trying to figure out how to get revit to work for us as we'd like to use it.
Mon, Nov 18, 2013 at 3:18:18 PM | Tagging 2 rooms with the same tag/area
Well then, I would treat it as one space - without a corridor dividing it- just define the corridor in 2D as passing through it.
Mon, Nov 18, 2013 at 3:19:21 PM | Tagging 2 rooms with the same tag/area
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
One thing I see people just starting out using Revit is them trying to force Revit into doing things the way they use to do them.  I'm not saying thats what you are doing, just a heads up that you will most likely have to change your way of thinking when it comes to Revit and do what revit wants in certain aspects.
Mon, Nov 18, 2013 at 3:25:48 PM | Tagging 2 rooms with the same tag/area
Revit will allow you to have two rooms with the same name and number..... but I don't encourage that in this application but go ahead.
It will just not total as one space.
Edited on: Mon, Nov 18, 2013 at 3:26:45 PM
Mon, Nov 18, 2013 at 3:26:40 PM | Tagging 2 rooms with the same tag/area
masseya
Re: WWHub
so you're suggesting using model lines instead of room separation lines.  I think that'll actually work pretty well.
Re: Teafoe5
Exactly, we're trying to figure out where things will work as is and where we'll have to change the way we think about things.  It's going to just be a long process of trial and error I suppose.
Thank you both for your input.
Alan
Wed, Nov 20, 2013 at 8:11:44 PM | Tagging 2 rooms with the same tag/area
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
If it's really neccesary. one of my posts can be helpful, i guess..
http://plevit1.blogspot.kr/2013/10/rooms-tag.html
want more?
You can get more tips at Enjoy Revit
tagging the surface area of a floor (revit2009)
Wed, Mar 3, 2010 at 11:14:36 AM
tagging rooms in linked files
Mon, Jan 13, 2014 at 3:26:05 PM
How to tag multiple rooms (composing one unit) with total area?
Thu, Dec 31, 2015 at 11:45:39 AM
Room Tags - Tagging all Rooms at Once??
Mon, Sep 17, 2012 at 11:40:17 AM
two seperate rooms but with one room tag
Thu, May 22, 2008 at 6:56:07 PM
Page generation time: 0.7503
