Forums >> Revit Building >> Technical Support >> Dimension or Detail Component?
Mon, Nov 18, 2013 at 1:44:40 PM | Dimension or Detail Component?
sbatocal
Hi, I'm fairly new in creating construction drawings using revit
What would be the best way to go about dimensioning ceiling heights in ceiling details?
In autocad I would use a dimension style with arrowheads and have it point straight down to "nothing" from the ceiling and say something like, 9'-0" to fin. flr. line.
If there is a way i'm hoping I could use this to also dimension grid lines on enlarged plans to indicate the distance to the following grid line that is not shown.
I hope I makes sense, if not i'll have to figure out a way to take an image of what i'm talking about.
thanks
Mon, Nov 18, 2013 at 1:50:23 PM | Dimension or Detail Component?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
In Revit you have to actually dimension to an object, there is no "faking it".  You could use a blank leader and text. I don't like doing that because it really defeats the purpose of Revit by taking away the correspondence if something changes you would have to manually change those numbers.
Mon, Nov 18, 2013 at 2:04:26 PM | Dimension or Detail Component?
If it is a section detail, include the level and break the view so that you compress it vertically.  Now dimension from the level to the ceiling.  If the ceiling is moved in the model, the dimension is now live and update accordingly.  << That is the proper Revit way.  Or use a ceiling tag that includes the ceiling height above the floor.
Mon, Nov 18, 2013 at 2:34:39 PM | Dimension or Detail Component?
sbatocal
Thanks! that did the trick for my typical ceilings,
unfortunately I do have some very detailed imported autocad details I was hoping I wouldnt have to recreate in revit in order to read true. For the sake of time I think I'll just fake in those somehow.
the transition to revit is brutal I swear I spend almost my entire day figuring out work arounds. the struggle is real.
Mon, Nov 18, 2013 at 3:00:49 PM | Dimension or Detail Component?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Revit has a high learning curve but once you learn its uses and can impliment them you will never want to go back to AutoCAD.
Mon, Nov 18, 2013 at 3:15:49 PM | Dimension or Detail Component?
You can always create model views and paste in 2D information from CAD.  Just learn to clean up CAD first!!!!!
You don't want all the linetypes or filled region types from an exploded CAD file.  There are multiple posts here on cleaning up cad.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=17194
Mon, Nov 18, 2013 at 3:24:16 PM | Dimension or Detail Component?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"paste in 2D information from CAD.  Just learn to clean up CAD first!!!!!"
I cringe a bit when I see that because it always seems that someone with not a lot of experience brings CAD in without cleaning it up so I try to not even use that as an option.  If someone must I make them bring it into a "dummy" project first to clean it up and make double sure they aren't bringing in CAD line types (which im sure is mentioned in your link somewhere)
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:15 PM
Nested Annotation Family in a Detail Component
Fri, Mar 16, 2012 at 8:56:45 AM
CREATING DETAILS USING DETAIL COMPONENT
Mon, Jun 26, 2006 at 4:00:03 PM
Embedded Detail Component and Object Styles
Fri, Feb 12, 2010 at 3:21:25 PM
Show user created dimensions within Adaptive Component in Sheets (2016)
Fri, Jul 1, 2016 at 1:55:50 PM
Page generation time: 1.5318
