Forums >> Revit Building >> Technical Support >> Surface Toolbar in REvit
Mon, Nov 18, 2013 at 2:21:18 AM | Surface Toolbar in REvit
amolese
Hello there
After using the surface tool on a created form in Revit 2013. Is there a way to reverse back the process and remove the surface representation so you can have access to the add edge/add profile tool for a more defined form before using again the surface tool on your form? Anyone? Please don't tell me to undo, this is a saved file which has been reopened for a rework.
Thanks
Mon, Nov 18, 2013 at 5:43:40 AM | Surface Toolbar in REvit
abdulameercp
How is the shape of ur form? i think you can simpply delete the divided surface. pls post snapshots of ur model
Thanks
Mon, Nov 18, 2013 at 6:42:30 AM | Surface Toolbar in REvit
amolese
Thanks I just figured it out after watching a video from Zach Kron. Just delete it. Thanks for taking time to reply. Actually the organic model hasn't got far yet. It is still a simple form, really not worth posting yet. Will do when finished.
Anyway to edit the BASICS Toolbar???
Wed, Jul 2, 2008 at 2:41:01 AM
Shading Toolbar
Tue, Jun 22, 2004 at 9:54:36 PM
Toolbar Flicker
Wed, Mar 24, 2010 at 1:21:06 AM
Quick Access Toolbar 2011 losing tools on startup
Thu, Aug 19, 2010 at 6:43:53 AM
Civil 3d surface to revit topo surface
Thu, Oct 13, 2011 at 7:14:34 AM
Page generation time: 1.3670
