Forums >> Revit Building >> Tips & Tricks >> Nurbs Roof Import
Thu, Feb 16, 2006 at 2:32:58 PM | Nurbs Roof Import
daveg
Hi, I'm working on a curved roof that I have created in max as a ruled nurbs surface between 2 spline curves which curve in 3 dimensions (ie i drew them in plan then moved the points in 3d to get the form I was after). Whilst I get the file into Revit, I have problems that when I select the form to make into a roof (as a massing object) I can only select a few of the faces to convert. Any ideas as otherwise I have to have a building half in revit and half in max. Cheers
misleading import of NURBS!!
Wed, Oct 3, 2007 at 5:19:04 PM
NURBS import
Mon, Nov 28, 2005 at 10:33:40 AM
MAX to Revit Roof
Thu, May 28, 2009 at 8:42:36 AM
scan polymesh import to revit
Wed, Apr 9, 2008 at 11:34:10 AM
REVIT and NURBS
Sun, Mar 19, 2006 at 9:34:11 PM
Page generation time: 0.2915
