Forums >> Revit Building >> Technical Support >> Stage Trusses ( technical name?) for awning support in Revit 2013
Fri, Nov 15, 2013 at 2:35:33 PM | Stage Trusses ( technical name?) for awning support in Revit 2013
LtMerc
Ok so I need to add some structure to a render I am doing for a patio. The awnings are just the generic ceiling model in Revit and I need to add something similar to a stage truss as found here on Revit City but a much much smaller version. I have tried modifying that but it doesnt go too well. Is there a family out there already or a technical name I can use to better search for one? Or is simply taking the time to make one myself the better option here? I am still much of a novice when it comes to making a family from scratch.
Mon, Nov 18, 2013 at 7:57:26 AM | Stage Trusses ( technical name?) for awning support in Revit 2013
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't know what a stage truss is so you will need to attach an image of what you want.  If it is something that is custom to your project you will most likely have to make the family yourself, which if you are a novice can be hard but it is essential to learn this anyway to become proficient in Revit.
Do we need to revamp technical forum?
Wed, Sep 22, 2004 at 3:06:24 PM
Open awning window in 3d
Wed, Jun 14, 2006 at 8:16:33 PM
symbolic lines on awning windows
Fri, Feb 3, 2006 at 7:11:37 PM
Creating trusses
Thu, Dec 29, 2016 at 6:44:09 AM
Simbolic Lines in CW Awning Windows
Thu, Oct 15, 2015 at 3:49:00 PM
Page generation time: 3.4231
