14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> painted cmu wall..
29 Posts No Rating |
I want to show a painted cmu wall in a rendering... When I paint the color onto the cmu wall, I lose the grout lines. How do I show the wall painted the color I want with the grout lines?
Change the color of the image file that is used for the CMU wall
Will the doing this alter the original cmu material? I've noticed that sometimes duplicating and changing one material also effects the parent material. I don't want to muck things up anymore than usual...
You need to use a different block with the color you want. Paint that material.
Sorry Tea - I didn't mean to jump in. Started the post and got distracted before I hit send.
Edited on: Thu, Nov 14, 2013 at 9:11:34 AM
"I've noticed that sometimes duplicating and changing one material also effects the parent material."
Create a new material for the CMU then you don't need to worry about affecting the original. Use youe HELP file and take a look at creating materials. Depending on what version of Revit you are on some versions are easier than others to use the material editor.
WWHub- No prob!
THank you. I will try it. I've created materials from scratch, just didn't want to unintentionally interupt something that's currently not broken. Also, this forum keeps posting my original reply, don't have a clue as to why it's doing that.
In 13 & 14, you do have to pay attention to assets because they may be used in multiple materials.
making the anther material with a bmp to it seemed to do the trick.. Thank you.
Looking for a source for png images to create blue painted cmu rendered image |
Thu, Jun 7, 2012 at 7:01:54 PM
CMU wall reinforcement and detailing |
Mon, Nov 22, 2010 at 1:32:03 PM
How to take quantities from painted surfaces? |
Tue, Oct 10, 2017 at 1:00:43 AM
CMU Wall |
Thu, May 7, 2015 at 12:15:47 PM
CMU + brick wall- brick is NOT bearing |
Tue, Dec 22, 2009 at 3:16:30 PM
