Forums >> Revit Building >> Technical Support >> Sharing Coordinates Conceptual Mass Environment and Project Environment
Thu, Nov 14, 2013 at 3:31:15 AM | Sharing Coordinates Conceptual Mass Environment and Project Environment
amolese
Hello there
I have designed a building in the project environment. I now have an organic structure which I will like to start from a conceptual mass and then insert into project where I will finish it. How do I ensure that the mass elements will insert in the right area of my project? Is there any way to share coordinate between project and conceptual mass?
Thu, Nov 14, 2013 at 1:26:58 PM | Sharing Coordinates Conceptual Mass Environment and Project Environment
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
There are no coordinates in a conceptual mass.  Could you do this right in your project with an in-place mass?
Thu, Nov 14, 2013 at 10:09:39 PM | Sharing Coordinates Conceptual Mass Environment and Project Environment
tanrevit
tanrevit Avatar
5 Stars: 2 Votes
the best way if Y both load the master plan to project file and massing file, insert auto origin.
Let try
Sat, Nov 16, 2013 at 10:14:00 AM | Sharing Coordinates Conceptual Mass Environment and Project Environment
amolese
In-place mass is too dodgy. I have been trying for the past 3 days to do the organic modelling there, but after creating all my splines the create form tool is not to be seen. It has disappeared. After tweaking with all the settings it showed up again, then again disappeared. I have tried circling through all the panels no luck. I have logged out and logged in and went into the edit in place mass and tried again to create form with my splines no luck. The create form tool is not there, simple. Thats why I wanted to use Vasari.
@Tanrevit Your answer is a bit vague. How do you do what you suggested. Please be more clear about this.
Ta for the replies Guys.
2013_reference line in project environment
Fri, Dec 14, 2012 at 12:40:58 PM
building environment
Mon, Aug 3, 2015 at 1:30:12 AM
Toposurface into Conceptual Mass
Sun, Aug 17, 2014 at 2:19:08 AM
Void Mass Not Cutting Divided Surface Mass
Wed, Jan 31, 2018 at 10:19:21 AM
Reverse the face of mass for roofing
Sun, Dec 14, 2014 at 12:21:36 AM
Page generation time: 0.5397
