Forums >> Revit Building >> Technical Support >> dimension to centerline of mullion
Wed, Nov 13, 2013 at 12:12:09 PM | dimension to centerline of mullion
ledgewood33
I am having trouble trying to dimension to the centerline of the mullions in my storefronts. I have another project where I was able to do so (I would start my dimension and when I hovered over the center of the mullion a dashed line would appear representing the centerline of the mullion.) in my current project I am unable to do so. does anyone know what the fix might be or what I am doing wrong?
Wed, Nov 13, 2013 at 12:19:56 PM | dimension to centerline of mullion
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Sounds like you were dimensioning to the 'curtain wall grid' and not the center of the mullions. Use the tab key to select. Putting a strong reference plane in the mullion family will also help. Perhaps your mullions are offset and the curtain wall grid is behind the mullion linework.
Curtain wall border Mullion - Profile to align at the centerline
Tue, May 27, 2014 at 9:23:55 AM
Trick for Offsetting Parameter Both Directions from Centerline
Tue, Sep 30, 2025 at 10:53:09 AM
dimension centerline toggle
Fri, May 23, 2014 at 2:30:28 PM
Dimension Stacked Walls
Thu, Aug 18, 2011 at 12:23:35 PM
Wall Sweep - Reveal; How to dimension to reveal centerline? (RAC 2009)
Wed, Apr 14, 2010 at 2:35:31 PM
Page generation time: 1.2125
