Forums >> Revit Building >> Technical Support >> Unable to create reveal in wall instance? Please any help would be appreciated.
Wed, Nov 13, 2013 at 8:33:51 AM | Unable to create reveal in wall instance? Please any help would be appreciated.
Kjammer
Hi all,
I am trying to make a wall from the Terreal Zephir Evolution facade, I was able to get the wall file and copied it into my project. However when I go to build that wall the vertical indent does not appear only the horizontal one. It gives me a warning that it was unable to creat the reveal because the sweep instance is outside of its wall but it is not, and I do not know where the sweep parameters are... At this point I really would appreciate help, I am so close.
Attached is images of my problem:
http://imgur.com/I5wX7El,PYMq9A8[1]
The first image is of the copied wall with the second wall being the wall I drew and as you can see there is no vertical lines to indicate the breaks.
Wed, Nov 13, 2013 at 8:49:19 AM | Unable to create reveal in wall instance? Please any help would be appreciated.
Vertical reveals are not part of a wall definition.  They have to be added afterwards.
Wed, Nov 13, 2013 at 9:02:01 AM | Unable to create reveal in wall instance? Please any help would be appreciated.
Kjammer
Well if you dont mind me asking is there another way to get that cladding effect?
Wed, Nov 13, 2013 at 9:42:19 AM | Unable to create reveal in wall instance? Please any help would be appreciated.
A material will give you that effect and no need for any sweeps.
Wed, Nov 13, 2013 at 9:44:46 AM | Unable to create reveal in wall instance? Please any help would be appreciated.
Better yet - go to their site and get the Revit files:  (Did you think of looking there?)
http://www.terreal.us/request-revit-files/
Wed, Nov 13, 2013 at 9:56:17 AM | Unable to create reveal in wall instance? Please any help would be appreciated.
Kjammer
yeah the wall i have in the image/ file was from their revit file I copied. I tried to contact them but to no avail yet... :/
ERROR: could not create integral reveal from wall instance. fail to cut wall.
Mon, Jan 8, 2018 at 8:30:21 AM
Splitting a wall with a Reveal
Fri, Feb 19, 2010 at 11:25:44 AM
Wall Reveal under Window Opening
Thu, Jul 17, 2008 at 6:45:24 PM
Wall Reveal by Face in 2010
Wed, Apr 7, 2010 at 10:20:06 AM
how to add a self made reveal to a wall while edit wall types?
Sat, Feb 12, 2011 at 10:53:31 PM
Page generation time: 7.9738
