Forums >> Revit Building >> Technical Support >> Exporting HVAC Duct Layout from Revit to Autocad - Hatching Problems
Tue, Nov 12, 2013 at 6:38:24 PM | Exporting HVAC Duct Layout from Revit to Autocad - Hatching Problems
Boggers89
Hey guys,
We are trying to export one of our HVAC layout drawings from Revit 2013 to AutoCAD but come across a problem when doing so. The lining hatch that we use to denote a specific insulation thickness doesn't come across into the autocad file, The hatch patterns we are using are standard AutoCAD ones so we don't know what the problem is. What is even weirder is the same hatching that is on some of our diffusion items comes across into AutoCAD but not on the duct work. Any idea's on what me be the problem?
Thanks,
Wed, Nov 13, 2013 at 12:33:35 PM | Exporting HVAC Duct Layout from Revit to Autocad - Hatching Problems
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
The bad news is, exporting hatch patterns from REVIT to DWG has never been pretty. Did you try dabbling with the fields on the 'Patterns' tab of the Export dwg / dgn dialog box ?
Wed, Nov 13, 2013 at 6:03:37 PM | Exporting HVAC Duct Layout from Revit to Autocad - Hatching Problems
Boggers89
Yep we tried changing all that with no luck, I have had it on other jobs when I have exported from Revit to DWG the hatch on half the job will work then the other half will not come thru or it will come through as a solid hatch etc.
Autocad MEP duct work question
Thu, Feb 17, 2011 at 11:12:01 AM
HVAC, Any Ideas?
Sat, Feb 25, 2017 at 10:05:24 PM
Revit MEP HVAC Lag?
Wed, Jul 4, 2012 at 10:58:46 AM
PROBLEMS EXPORTING GRAPHIC COLUMN SCHEDULE TO AUTOCAD
Thu, Jan 27, 2011 at 12:23:31 PM
Importing AutoCAD MEP 2008 files into Revit Architecture 2008
Fri, Nov 16, 2007 at 1:27:47 PM
Page generation time: 2.3294
